Data Reset
01-02-2020 12:29 AM - edited 01-05-2022 10:12 AM
My data was reset to 1023.999 MB instead of 1024 MB when it was renewed. Just wondering why it is not reset to 1024 MB?
Service
01-02-2020 03:19 PM
@Sunshine-754 wrote:My data was not on. It shows 0.001/1024 after it resets itself.
Yes PM's system sometimes shows these nominal amounts of data being used, sometimes it's negative data (benefit!), but normally there's 2.3mb of buffered/ghost data that's shown after enabling data on the phone. Usually this can be reset by turning your phone's data/airplane mode on/off.
However, one of my account's phone that has data turned off and it still shows this nominal amount of data being used, not sure why that happens but I don't worry about it as it seems to be one of the many quirks in the PM system:)
01-02-2020 12:23 PM
@Sunshine-754 wrote:My data was reset to 1023.999 MB instead of 1024 MB when it was renewed. Just wondering why it is not reset to 1024 MB?
Perhaps, just a system bug, don't worry, it may fix itself with time/new month.
01-02-2020 05:01 AM - edited 01-02-2020 05:02 AM
This is about 1 kilobyte. It shouldn't do this but is unlikely to cause any differnce in service.
01-02-2020 12:50 AM
01-02-2020 12:44 AM
@Ed404 wrote:
@LoveMyBolt wrote:Another .001 thing. Seems to be a rash of these.
Was your data on? Did you send an MMS?
If the display shows it as 0/1023.999 it's on their end and isn't related to user doing anything with data. Probably a system glitch and didn't round up or something. I wouldn't worry about 0.001 MB it's nothing.
I would surmise that it's a similar related effect.
It is nothing but I like seeing zero used and even, clean numbers for the bucket.
01-02-2020 12:33 AM
01-02-2020 12:31 AM
