07-14-2019 05:46 PM - edited 01-05-2022 05:52 AM
Hello!
I've moved into a new condo and we don't have our internet hooked up yet. I currently have 4.5GB of data a month which is normally fine, but without the wifi at home I'm worried about overages!
Is there a flat overage charge? Or an add-on you can tack on when you notice you're near the end of your monthly data?
I'm currently at 1.7GB (and about halfway through the pay cycle), so I have some time before I'm out of data, I just want to know my options.
My Account
07-24-2019 08:13 PM
@Anonymous hi an intertube is that something that goes in a tire?
07-24-2019 07:56 PM - edited 07-24-2019 07:58 PM
You've been here a while...it would be more understandable and have some flow if you replied to someone. A post just out of the blue has no context.
On top of that...this is a solved thread. Unless you have something to say beyond what has already been said then there's no real point in adding more.
But hey who am I. Just a random punter out on the intertubes. Do what you like.
07-24-2019 07:15 PM
No need to increase your base plan, however, if your extra data usage was a one-time thing. I say this since the 1gig add on stays there until you use it all.
Mind you, PM has such great deals, you might just want to increase your data for $5 or $10/month.
07-24-2019 07:13 PM - edited 07-24-2019 07:15 PM
... and look for deals with telecom companies. In Nova Scotia, I deal with City Communications, and pay about $69 for my high speed data plan, taxes in. I chose not to pay over $110 for the same thing from other telecom companies.
07-24-2019 07:11 PM
You should always click the "change plan at next renewal" box so that you don't lose any time you have in your current period.
Once it starts the new period, you will have the new data amount.
07-24-2019 07:09 PM
But beware that you first have to add money to your account in order to buy extra data or any extra options. If you don't have money or enough money in your account for the option you are buying, it will kick you into the screen where you can add money. But it won't add the option, or put you back to the screen where you were trying to add the option.
So - look to see what the option costs, add that amount to you account, then go and add the option.
The way it works if a little wonky, but once you get used to it, it's okay.
07-24-2019 07:06 PM
That's one of the HUGE advantages of Public Mobile. Your data is pre-paid, and when you run out, rather than charge you horrendous overage fees, your data just stops. But wait... there's more! You can buy extra data at reasonable rates ($30 for 1 gig if memory serves) and it will just hang in there until you use it. That is, it does not run out. You can use 100 meg of it and have 900 meg left for other times you go over. How's that for COOL? Buy it and it doesn't run out! What other telephony company does that?
I tell my friends with kids that this is the ONLY way to go. No overages from your kids. And guess what? Once they run out a few times and can't get any more data until their renewal date, they learn pretty quickly to watch their data usage.
07-22-2019 10:37 AM
@Jazminnie25nothing to worry about, there's no such thing as overages with PM. Once you hit your max allowed amount for the month then the service will be locked until your cycle re-sets the next month. You can purchase the 1GB add-on, however if you think your situation is going to take awhile, like a couple weeks, then I recommend you just increase your base plan to one that offers you more data. Might be cheaper that way.
07-16-2019 03:04 PM
Since you moved to a new area, I thought you might benefit from some tips
- Get your internet hooked up asap. New condo? Find out which ISP your neighbours are using.
- Find your local hotspots. In some areas like downtown, you may even have free wifi. How about nearby cafe?
07-14-2019 06:14 PM
No problem that's what we are here for. Glad to help and THANK YOU FOR the questions.
07-14-2019 06:12 PM
Thanks for all the help! I greatly appreciate it!
07-14-2019 06:09 PM
It will add 4.5 plus .5 automatically. in self serve you'll total of 5.0 GB available to you for the month.
07-14-2019 06:06 PM
It looks like there is a better current offer going on now. Thanks for suggesting I check out the other plans!
07-14-2019 06:05 PM
I checked out the current plans and there's the $40 for 4.5GB with 500MB if you do auto-pay. So I swapped to that for next month, but if I switched to that this month would it auto adjust the data limit? (I do auto-pay)
07-14-2019 06:03 PM
@Jazminnie25 wrote:I can do those changes myself in the self-service section? Would it affect any current "promotions" that I'm a part of? I feel like when I got this plan a couple months ago when I first switched there was some sort of $40 for 4.5 thing going on.
If you renew your current plan then "no".
If you change, then you must pick from current offers (so maybe yes, maybe no).
07-14-2019 06:02 PM
Any promo freebees are lost only when you due a plan change.
07-14-2019 05:59 PM
07-14-2019 05:52 PM
@Jazminnie25 If you run short, just prepay your current plan then click this: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437 to send a private message to the moderator team requesting an early renewal. Contact them before you are really out as sometimes they answer within in 24 hours, but usually take several days.
You could also change your plan early to the $50 plan and then immediately put in a change plan back to your current plan when the $50 plan expires.
07-14-2019 05:51 PM
Thank you!
07-14-2019 05:49 PM
You can get data add on thru your self serve account. See the options there to add more to tie you over till next month.
07-14-2019 05:49 PM
So is there a way to add more data for one month? Or am I done when I hit 4.5?
07-14-2019 05:47 PM
Plans are prepaid, so NO overages charges.
