Data Overage
Kovacsa
What happens when you run out of data on your subscription plan? Are you charged for any extra data that you use or do you you simply run out of data without additional charges? Thanks!
@Zelda wrote:
That is what I like about Public Mobile, they never charge you without you knowing.
True @Zelda
But one also needs to PAY ATTENTION to what they're signing up for.
There are some who come here, input their credit card for a plan which enables auto-subscription, and leave (without porting out their number) only to find out months later their card is still being charged.
Why, because they neglected to make any account changes.
 They just 'figured' if they weren't using the service they wouldn't be charged.
Better yet, those same folks think they were overcharged and are due something.
They're not.
Zelda
Lolo_1234
Furthermore if you are lucky you might have a little extra "free" data before it cuts out 🙂
Meow
You have to look at each plan small print but I believe you will be just cut off when you use all your data. That is why PM has data add-on for you to purchase 😋
