03-09-2026
11:21 AM
03-09-2026
03:28 PM
computergeek541
Hey everyone.
My phone’s data is not working:/ i’ve tried resetting network settings, my phone, powering off, ect. I had data yesterday, but this morning it quit, which also just happened on saturday. So i did the recent update on my IOS, and it was good for the whole day sunday, until this morning. Even have switched to LTE, 3g, nothings working. Hoping the community can help me out
03-09-2026 11:30 AM
I have used 6Gb/100GB so i don’t believe thats the issue:/ someone mentioned getting public mobile to reset my account on their end!!
03-09-2026 11:24 AM
hi @josiking10
you sure you have enough data? login My Account and check the usage there
also, make sure you disable Data Usage Limit on your phone.
but if you need, ask PM support agent to help and check. submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit ticket by direct message:
03-09-2026 11:23 AM
@josiking10 Might need ask support to refresh your account on the back end and have them investigate
Public mobile prefers
you use the orange chat bubble bottom right of screen . If that dosent work you can instead send a private message To CS_Agent
