10-26-2018 08:08 PM - edited 01-05-2022 02:19 AM
What is the most amount of data that you have seen available? What happens when you go over your data limit? Does it just turn off?
Thanks
10-26-2018 11:21 PM
I thought about buy a extra phone and running two sims but that still would only give me 16 gig total. My total usage was 150 so its won't be practical.
10-26-2018 11:11 PM
You can always get two sims, which means you get two accounts. If you have a dual sim phone you should be good. I doubt that it will be able to handle too many connections if you're thinking of using it as a hot-spot though. I can only imagine that it will get pretty hot as it tries to feed all that data to other devices. Not sure if this helps but it may lead to other ideas for you . . .
10-26-2018 10:12 PM
The most that I have seen is 8gb. You can put together your own plan if you like. You will see various options that are available to you. Some even have bonus gb. There is a 6gb with a 2 gb bonus. Haven’t seen anything bigger then this.
10-26-2018 09:36 PM
In my area all that is available is 3G and the speed is still way faster than my Bell home internet. It would be awesome if you could get unlimited data from PM but I can't see that happening.
10-26-2018 09:25 PM
@Ruggybuggy wrote:I was hoping to stream everything at home with my PM account so I could get off Bell's home internet. We stream all our TV programs and movies through Bell. When I checked the data use it was 150 gig on average per month. My Bell account has unlimited data even though it's only streams at 4 mbps while my PM is capable 50 mbps. I guess I'll have to keep the home internet on Bell.
The data plans we told you about aren't full LTE and are a throttled LTE we call them LTE Lite and PM calls it 3G.
10-26-2018 09:08 PM
You should check out some of the 3,Rd party ISPs. Their rates are pretty good vs traditional ISPs.
10-26-2018 09:05 PM
10-26-2018 08:23 PM
You can get 24 GB on a 90 day term for 150$ use it as you wish in that 90 day period and a couple days before it runs out ask mods to renew plan early. If the data last you 60 days then it works out to be 75$ per 30 days.
10-26-2018 08:16 PM - edited 10-26-2018 08:19 PM
@Ruggybuggy wrote:What is the most amount of data that you have seen available? What happens when you go over your data limit? Does it just turn off?
Thanks
I think 8gb was the biggest I have seen I maybe wrong it didn't interest me so I don't pay attention lol. Yes if you use your data up it just stood there are no overages
ETA yes 8GB Canada wide casing and international texting $50/30 days
