DAt
10-23-2018 01:20 PM - edited 01-05-2022 02:16 AM
Please let me know if the data run out on my phone as i cannot down load. anything. itd show Min?Mb.what does that mean.
Thanks
Joining Public
10-23-2018 01:23 PM
@larmond wrote:Please let me know if the data run out on my phone as i cannot down load. anything. itd show Min?Mb.what does that mean.
Thanks
If you login to the selfserve and on the overivew page look down the left side and int eh Addon section if data is not listed there you have used it all up. What plan are you on because you can always go through your usage history to verify it matches what your plan gives you.
