DATA
09-04-2019 04:30 PM - edited 01-05-2022 06:51 AM
09-04-2019 07:58 PM
Public Mobile has no throttled speed after you use up your data
When you use it up, it stops. That way you don't get overcharged for anything ...
@tonyluckyboy wrote:hey guys, after you used your data limit publicmobile it shuts your data off?? or it keeps going at lower speed?? if not they charge you for going over the data limit?? please let me know guys...thank you...
09-04-2019 04:35 PM
thank you so much...you clarified me....
09-04-2019 04:34 PM
Once data is used up it's shut off don't worry about overcharged.
Options after you use up your data is to buy a data add on.
No lower speeds..once used up you have to wait to plan renews next month or buy a data add-on
09-04-2019 04:33 PM
@tonyluckyboy after you use it all up it stops, does not charge you anything and does not keep going at a lower speed! You should get a warning text at 50% and again at 95%
