Custom plan
11-03-2018 01:18 PM - edited 01-05-2022 02:23 AM
Hey all,
I was paying $50 for 8GB of data. It was a promo I signed up under in Sept.
I just went to custom plan and for $50 Can/USA calling, international texts, 6GB +2 bonus.
Does anyone know if the bonus 2 expires? or is there any reason not to switch my plan to include USA calls?
Thoughts?
11-03-2018 06:14 PM
I would not worry about it. If you are happy with the plan, go with it until there is a better plan that suits your current needs. These things are usually grandfathered, but there is nothing saying it will not be changed either. Go with the flow, and hope for the best!
11-03-2018 02:00 PM
That lack of fine print was a concern for me also. Public Mobile uses this as a gimmick, to echo the bonus data other providers give, but take away in the fine print.
until they give notice of a change to your specific package, it’s all the same, and will stay.
You must have got into the regular 8Gb plan before it was modified to include US calling. When the promo ended, it had been modified to include the US calling. The current choose your own plan is exactly the same as you are on, plus US calling, at the same price. If you don’t need US calling, stay the way you are, if you need US calling, you can choose the the CYOP, or buy US long distance in the $8 or $15 long distance Addon.
11-03-2018 01:53 PM
Public Mobile has so many plan options sometimes the pricing doesn't make sense. In this particular case there's no extra cost to go with Canada and US calling. So why not! As with all plans, changes are subject to the terms of service. All plans are equally immune to future changes.
11-03-2018 01:31 PM
@Degus222 wrote:Yeah, I am just concerned the bonus 2 GB of data might expire or end because I need 8GB.
There's no fine print that says it would. I've not read here that that would happen.
11-03-2018 01:29 PM
11-03-2018 01:27 PM - edited 11-03-2018 01:27 PM
@Degus222 wrote:The custom plan had the same as the promo but with USA calling. So it doesnt seem like I would want to go back.
Ah freedom. Them's're your choices to make. Can't help you there. 🙂
11-03-2018 01:23 PM
11-03-2018 01:20 PM - edited 11-03-2018 01:21 PM
@Degus222 wrote:Hey all,
Thoughts?
Once you're in a plan, you're in it. They could change the price with 30 days notice but you still have your plan. But if you switch from a promo, you probably won't get it back.
