Currently offered promotion
SevenQ
The current offered promotion of 40gb unlimited minutes Canada- US minutes
does it mean I can call the US without long distance fees and is it offer for Quebec subscribers.
Thank you
@SevenQ   it is only available for QC customers.  You can call US without Long Distance, as well, the data can be used in US too (no roaming charge)
If you are no in Quebec, there is indeed workarounds. Thanks @Brilliance for testing it out. Please check his post:
https://productioncommunity.publicmobile.ca/t5/Get-Support/Plans-by-Province/m-p/1001866/highlight/t...
caper1622
Yes
Meow
Both correct!
@SevenQ  Yes and yes
