2 hours ago
I requested and paid for a 1000 minute add on to my account in early august. It has appeared on my account as a us/canada addin. Which I don’t need as I have unlimited calling.
would a cs_agent please look at this and respond.
2 hours ago
@TerryD59 wrote:I applied for the uk add on and was credited with us
easy mistake to make. Just use that quick link to send a message to Customer Support and they'll fix it for you...pronto.
2 hours ago
2 hours ago
@TerryD59 wrote:How do I send a private message. The option to raise a ‘ticket’ to an agent did not work. Therefore the chat box advises us community page with reference to cs_ agent. Such a useless system for anyone not used to gadgets
Use this link, if the chatbot failed you..
watch the little envelop icon top right side of page will be highlighted when they respond to your message.
2 hours ago
ask PM to reset the account on the system
open ticket with PM using the Orange Chatbot icon on the lower right. Type the question Submit ticket and select Contact Us to get to ticket open screen
or message them using this
2 hours ago
I did all that produces nothing and keeps going in circles
2 hours ago
2 hours ago
you bought the wrong add-on. If not used at all, ask PM to change it for you
2 hours ago - last edited 2 hours ago
which add-on are you interested in ?
added...to start process of Customer Support, click on the orange bubble, bottom right side of the page.
2 hours ago
You would have to send a private message to support for them to look into this and possibly remove it
