Credit of $5 before June 6,2022
LakpaSherpa
I referred to a friend before June 6, 2022. And there was an offer of $5 going on. But I haven't received it yet. When the cred
JL9
You haven't received a single $5 credit yet? It has been over 2 months, so if that is the case I would definitely connect with a CSA is your friend still a PM customer, did they get their one time 10 credit and their 5/month credit? Did you receive your $1/1 point for the referral? I am assuming no if you didn't receive your 5 credit. Confirm they are still with PM and then get aCSA to investigate so they can manually resolve this.
Timer
@LakpaSherpa
your friend is still active with PM.
if yes then contact to support team by CS_Agent .
@LakpaSherpa   You never got any payment for June , July and August? or just missed this one?
First, you have to check if the one you referred got his $10 one time in his account
If so, you can try to open ticket with PM CS agent and confirm:
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
start by typing : Contact CS Agent
then Click "Contact Us"
then Click "Other"
finally Click "Click here to submit a ticket"
