Coverage
CelticBoy
If I get public mobile 4g plan for Mother. Is coverage strong, Oshawa, Port Hope & Coburg area?
Both calls, email, SMS and MMS
Thank you
self solution removed
CelticBoy
Thank you I'll give my phone (Toronto) to my Mum for few days. She can then check coverage for PM good there
will13am
@CelticBoy , the coverage in Durham region very good.  You mention 4G plan, just to let you know that all plans provides for the same network access.  The 3G/4G/5G is a marketing term for the degree of speed throttling.  You should select a suitable plan based on the amount of expected data usage and not really worry so much about the 3G/4G/5G designation.
Meow
Do YOU have PM service? If you live close by you can test it yourself. But I believe that area is very well covered.
