Activation issue
10-26-2023 07:19 PM
10-26-2023 10:33 PM
I didn’t receive any number !! Please send it back.. still same problem
10-26-2023 07:46 PM
HI @Alaa2
i sent you a number already. Check your Community inbox
10-26-2023 07:43 PM
I called 611 not find answer
10-26-2023 07:30 PM
Thank you…
can you please send a an agent phone number..
10-26-2023 07:25 PM
@Alaa2 wrote:I called my old carrier and they released it but still not received any call or text
Hi @Alaa2
reboot the phone once. A reboot is usually needed after the old carrier release the line
if it still does not work, then call the porting team number I sent you, they will confirm
and you are able to make outbound calls with your PM sim card?
10-26-2023 07:24 PM
10-26-2023 07:21 PM
I did
10-26-2023 07:20 PM
HI @Alaa2
if I am correct, you requested porting. If you did request porting,your number has not been ported yet. You receive a text from your old carrier yet?
I will send you a number to call to porting support team, they will check and advise. Check your Community inbox for the phone number
10-26-2023 07:20 PM
@Alaa2 , did you perform a number transfer as part of the activation? If you did, make sure to acknowledge the number transfers from the old service.
