Coverage plan
Laila6
I would like to know: is my Public plan good for The States?
Thanks
2 REPLIES 2
hi @Laila6 we are just customers and we don't see your plan, you have to login My Account or PM app to check yourself
US coverage is included if you have a Canada US or Canada-US-Mexico olan
hairbag1
@Laila6
if you log in to your account, you'll see your current plan details. If you have the Canada/US plan, you'll have service in US as well as Canada. Just make sure you enable Roaming so you can use data whilst in US. Also, you must have a newer cellphone to be able to talk while in US....not all VoLTE enabled cellphones will work there...here's some reading with a device checker at the end of the article..
https://www.publicmobile.ca/en/get-help/articles/volte
If you have a Canada only plan, you can buy one of the US Roaming add-ons available for use there.
US Roaming⁷
15 to 30 day packages.
Unlimited U.S. Talk and Text Bundle....$15
Unlimited U.S. Talk, Text and 5GB Data Bundle (15 days)....$30
Unlimited U.S. Talk, Text and 5GB Data Bundle (30 days)....$40
