08-27-2023
11:07 PM
08-27-2023
11:09 PM
computergeek541
Hello,
I was not able to port my second line from Koodo to Public Mobile. Everything I've tried didn't work. When I try to login into my PM account my password doesn't work. Please help me
08-27-2023 11:42 PM
Yes the first one was successful
Second when I tried to activate the number via PM app it says to contact PM support because I'm porting from Koodo. When I contact help support through the chat they ask me to log in again and I don't know why I'm not able to login
08-27-2023 11:31 PM
I used my wife's email
08-27-2023 11:28 PM
Reset my password but when I tried to login again it says password doesn't match
08-27-2023 11:25 PM
Didn't use IMEI or account number
My koodo line still working
Used the same email
08-27-2023 11:15 PM
Hi there @Firpe
Please try to reset your password and then log in. If you have purchased a plan, get the Public Mobile app and then you should be able to transfer your number during activation. Hope this helped!
Regards,
Abheer
08-27-2023 11:13 PM
Post
