Could not find the promo code under friend referrals
Djah
How do i locate the promo code under my account/my  referrals
@d_oreen
much less work to just log in to your account using your laptop...it's on the very first page you come to ..right in Sharing Is Caring....get your personal link...xxxxxx.
d_oreen
Hey Djah!
I just checked mine..I think its updated so definitely looks different. If you get to your overview with the options on the left, click My Rewards. From there, through the popups, one should say "Visit my Rewards" right in the middle, even though it looks like you have none. That brings you to your dashboard where you'll scroll down and see a bunch of beige targets, one should be "Refer a Friend" ...scroll down to he bottom of the targets and the code should be there. Hopefully that helps!
Dunkman
@Djah
Your referral code should be shown in your overview page.  On the top of the page, Sharing is Caring banner.
Also, should be shown in the rewards page.  Under Sharing is Caring.
Emleh
When your in my referrals, it shows at the top the contest they’re holding right now. Under that it says ‘start referring’. When you click on it, it shows your code that you can copy. ‘Refer-a-friend’ they call it too.
