Correct date format
nata_lya
Trying to put a ticket. It is asking to put a date but does not suggest the format it should be entered.
I tried variations but can't seem to get the correct one.
yyyy.mm.dd
mm.dd.yyyy
mm-dd-yyyy
yyyy-mm-dd
None seam to be acceptable. Any suggestions?
nata_lya
Thank you for your reply. I selected another option and submitted. Case closed.
It would be nice to have the required format of data shown since all the fields are required to be filled.
@nata_lya  - I don't think I have come across this issue before..where were you asked to enter a date?
@nata_lya   try to open ticket by direct message then :
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply you there
