12-28-2023 10:31 PM - last edited on 12-29-2023 12:24 AM by computergeek541
As I have transferred my number to public mobile, still after 24 hrs not getting incoming calls and messages. While calling to this number it directly goes to the voice mail. How to fix it?
12-28-2023 10:39 PM
@Sijoj , are the calls going to the voicemail from the old provider? Did you verify the transfer request SMS sent to your old provider? If you did not, then your number transfer has failed. You can call the porting number in the link below and they will assist with fixing it.
