Connect Sim to plan
Larry13
Connect Sim to plan
Dolphin12
Make sure you use the app. We started the process on a computer then where prompted to use a QR code to register. It didn’t go well and I have a ticket open to correct the errors made.
@Larry13  If by chance your trying to replace a SIM card to existing account log into your my acccount and go to profile tab to sim swap the number
SIM  SWAPPING  profile tabs
@Larry13
existing account and have a new sim card?
if so, you will need to login My Account and go to Profile page, click the Pencil icon beside the sim card number and you can then update the sim card number
https://myaccount.publicmobile.ca/en/account/profile/change-sim-numberhttps://myaccount.publicmobile.ca/en/account/profile/change-sim-number
@Larry13  Do you have physical SIM card in hand or are you wanting to do eSIM if phone supports it . In both cases please download the app and start the activation by picking plan and subscribing
dust2dust
New account? Old account? New sim? Old sim?
