Confused about SIM & eSIM
Bobkat
I got a regular SIM. Am I able to get a 5G/4G plan?! Or will I need to get an eSIM to get a 5G/4G plan?!?! I think I can with a reg SIM but I'm not 100% sure!
Help!
Please and thank you!
HI @Bobkat you can use either
but if you are unsure what is eSIM, then that mean you don't need eSIM, leave it with physical
Bigjay83
Both the Physical SIM and the E-SIM has 4G/LTE/5G. I suggest that you check your phone to find out if it is 5G and E-SIM compatible. Best of luck and welcome to Public Mobile!!
@Bobkat
Both will give you 4G/LTE/5G. Only difference is SIM is a physical SIM and eSIM is an electronic SIM if your phone is compatible with eSIM.
DennyCrane
All sims have access to all plans and all networks. I recommend physical sim cards with PM, as esims are new and there are still issues with them. Physical sims give you more control and flexibility.
DDM69
Yes a regular SIM card will work fine.  Enjoy the service!
