05-03-2022 06:21 PM
Hi there,
I received a notification telling me my password was compromised. I seem to have 2 public mobile log-ins. I think one is for the community? The following username has a compromised password:
Mlambie04
and I don't know how to edit it. When I go to change passwords, it only changes the sign-in password associated with my email. Are there typically two passwords for public mobile?
05-03-2022 08:05 PM
@Mlambie04 - what do you mean "Mlambie04" has a compromised password?
What message did you receive to tell you this?
Community Account has totally different login credentials then either SelfServe/MyAccount credentials.
05-03-2022 06:44 PM
Funnily I received a notification too for another login saying there was a data breach. Mine was done via a Google notification. How were you notified of your PM issue? I guess it is a good reminder to say vigilant and change pws every now and then.
05-03-2022 06:28 PM - edited 05-05-2022 05:52 PM
You have your community account that uses your username Mlambie04 and a password to sign in. To rest the password for your community account it is just sent to your email. You appear to have signed in just fine.
Your self serve account has a username that is your self serve email. It also has a password that you chose. When using the forgot password link you need to remember your security question and answer to reset your password. Did you try mire than 5 times to reset your password?
To contact customer support :
Submit a support ticket via Simple--Simon the chat bot Click here
Or if you prefer or cannot submit a support ticket you may send a private message : Click here
To pre-verify add in your private messaging only your full name, address, email, phone # & 4 digit account pin #
05-03-2022 06:28 PM - edited 05-03-2022 06:29 PM
Your community password can be changed by clicking on your avatar and going down to "My settings". You'll see the "password" on the 2nd tab.
You can also change your community e-mail there as well.
