Complete activation
pmdeery3
Complete my activation please
Using my old phone number
if the account was setup and just the porting was incomplete, there is a porting assistance team you can call and ask for update.  I can't post the number here, but I will message the number to your community inbox.  Please check and call them
But if you cannot reach them or they said they cannot help, you will need to contact PM using this link:
And CS_Agent will reply to your community inbox, check here:
https://productioncommunity.publicmobile.ca/t5/notes/privatenote
pmdeery3
My phone number transfer is incomplete
Chalupa_Batman
Public Mobile is a self serve service. You need to activate the account yourself. You download the app and follow the instructions. If you're using an older phone, it may not work. Check your IMEI number on this link to make sure your phone will work here. If not, you may need a newer phone.
To confirm if your phone will work with Public Mobile, please see this link. At the bottom of the page, you can insert your IMEI number and the system will advise you if it will work with Public Mobile.
https://www.publicmobile.ca/en/get-help/articles/volte
Use Public Mobile's VoLTE checker as a guide only, as results are not always 100% accurate.
slusagm
physical or eSIM? At what point of the activation you are at? Tell us more
Or Reboot phone and login app again
