Compatible phones - iPhone 12 ?
PascaleG
Bonjour,
Is an iPhone 12 compatible with Public Mobile? It's not in the list of compatible phones.
Thank you
pkaraa
When I was searching for a phone in nov last year I looked at iphone 12 and it was compatible.
Then I found a killer deal for XR and bought it. Loving it.
@PascaleG
Yes is will working with Public Mobile.
visit Here link to review full information,
Public Mobile uses the following frequency bands:
  • 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
  • HSPA: 850 MHz, 1900 MHz (UMTS).
visit  Here link, to check it all Provider in Canada about compatibility with any device.
@PascaleG wrote:
Bonjour,
Thank you
@PascaleG  - yes, your iphone 12 is compatible with Public Mobile.
But if you like to see for yourself check
https://www.kimovil.com/en/frequency-checker/CA
https://willmyphonework.net
0PX9O4
@PascaleG
Yes it sure is 🙂
Not all compatible phones are listed.
