Community Rewards
murtro
I'm new to trying to get community rewards. Any idea of approximately how many posts or replies you'd need to do to qualify for the lowest level $1 reward?
Thanks!
@murtro
The CS_Agent doesn’t give out the formula on the Community Rewards but the more you participate on this Community…there is a good chance you will receive a monthly credit or points.
Meow
There is no set number for posts, Bravos nor Solutions. Reward is based on PM's secret formula and it might depend on number of participants per month.
Just posting will not you get any rewards. QUALITY answers and willing to help others (based on Bravos and Solutions) might get you some Community rewards.
Basic idea is to HELP others not to make a living of rewards. Some spend huge amount of time being helpful but you have to ask yourself is it worth it for max of $15/month.
@murtro
By participating , reading and helping others with questions . And learning and sharing and good things will happen
ranked chart here
Hi @murtro
no set number.  It is a secret to PM how to determine top %, but also depends on the overall participation
Generally, it is easy to get 1 or 2 points a month.  Spend 5 or 10 minutes a week to help (reply posts with good insights) should be sufficient.  But for those to get 5 points, it is a more dedicated work.  10 or 15 points are almost like Full time job 🙂
Good Luck
