Codes for iPhones
Greg45
iPhone IMEI code:
*#06# Gives you the phone IMEI which is your phone identifier for the hardware of your phone.
iPhone field mode code:
*3001#12345#* It opens the field mode that has the internal settings of the iPhone, the cell information, and newest network settings
iPhone call forwarding codes:
*#67# you can check the number for call forwarding provided the iPhone is busy
iPhone call minutes Codes:
*646# Postpaid users will be able to check the available minutes
iPhone bill balance Codes:
*225# Postpaid users will be able to check the bill balance
iPhone account balance code:
*777# Prepaid users can use this code to check the account balance
iPhone configuration code:
*# 33# This code will allow you to check a number of configurations on your phone for your calls, SMS, and data.
iPhone operator code:
*#76# To check if the connected line presentation is enabled or disabled
iPhone call forwarding code:
*#21# All your call forwarding settings will be available with the help of this code
iPhone use of information code:
*3282# To get details on the use of information
iPhone missed calls code:
*#61# For checking missed calls
iPhone call verification code:
*#62# To verify the phone number for call forwarding when the phone is in no service
iPhone EFR mode code:
*3370# It puts your iPhone is EFR mode. EFR stands for Enhanced Full Rate and it is meant to increase the quality of the iPhone
SMS center Code:
*#5005*7672# This secret phone code allows you to check SMS center
iPhone outgoing calls code:
*331* Allows you to bar your phone from making outgoing calls
iPhone call waiting code:
*#43# This code helps you check the call waiting status
iPhone activate call waiting code:
*43# to activate call waiting
iPhone deactivate call waiting code:
#43# to deactivate call waiting
iPhone phone number code:
*#31# Use this secret code to hide your phone number
iPhone forwarding code:
##002# it helps you to disable all call forwarding
iPhone block number code:
*#30# It allows or blocks a phone number for calling you
@Jackhyf63 wrote:
Did you have unlock code for iPhone6s?
iPhone doesn't have network unlock code to use at other carrier, no such thing.
iPhones are unlocked by having manufacturer whitelist the serial number as unlocked.
These have nothing to do with unlock codes.
In fact, not all of these kinds of codes work for all carriers.
Jackhyf63
Lieux
In fact I tried some of them with my iphone 5s and....nothing...doesn't work... Why @Greg45 ?
RobertQc
@Greg45  Again, good info but you could always make 1 post, and the subject "Codes for Andriod & Iphone", No need to make a different post for each type of phone.
