3 hours ago
Worst company to deal with. Won't let me into my account to close it. Keeps just asking me to pick a plan.
2 hours ago
hi @Jessie24
if you are already using PM services and got the "Pick a plan" error when you login, it just mean problem with login account. You just need a PM support agent to sort it out for you. Please message them here
2 hours ago - last edited 2 hours ago
@Jessie24 If you can’t log in to disable auto pay ( auto subscribe ) you can send direct message to support and ask them to remove the credit card info on file right away . And you won’t be charged again
send direct private message to support .
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
2 hours ago
@Jessie24 , what exactly is the problem? Are you trying to activate and running into issues or are you an existing customer having problems with your account? If you need assistance from support, use the link below to send them a private message.
