Clock
10-09-2022 07:12 AM
Did anymore notice that our cell phone time is about 2 minutes faster than the standard? I believe it is caused by the server. It is not a big deal. But sometimes it is not convenient. I hope PM can do a calibration.
Service
10-09-2022 11:51 AM
My friend had the same issue last year and it is not an PM issue.
It was his phone setting. Whenever he receive a text message his reply would go to the second line because it was not sync to the times of the replies.
Just adjust the clock on your phone but let us know what make and model of your phone so we can help further.
10-09-2022 11:49 AM
@Maggie1 It likely it is your device issue. Cellular network time is very accurate.
Try to reboot the phone first
If still not working, go into your time setting, disable sync with network time first. Manually set to another time, then go back and re-enable network time sync and see if it works
10-09-2022 11:41 AM
My phone's clock shows exact time to the second as my radio controlled ('atomic') watch. No issues here.
10-09-2022 07:41 AM - edited 10-09-2022 07:41 AM
Under your devices time settings, make sure that your time is set to the network calibrated time.
If this is not toggled on, you may not match the network's set time.
10-09-2022 07:21 AM
@Maggie1 No issues on my end, time is accurate
