01-07-2018 10:45 PM - edited 01-04-2022 03:16 PM
Hello,
I recently upgraded my phone to a uhans i8. Since then the data has not worked. I am using an old SIM card. Do you think this is a hardware issue or a sim issue? Or is it something else all together?
I would love some help,
ED
01-08-2018 06:22 AM
I don't think those are the correct specs for your phone. If voice calls are working, it means you have WCDMA 850 and/or 1900.
Data is available on all frequency bands, so I would suspect your APN settings are incorrect.
@Ed wrote:The net work avaliable for the phone is
2G: GSM 850/900/1800/1900MHz
3G: WCDMA 900/2100MHz
4G: FDD-LTE Band 1/3/7/8/20.i have no idea what this means. Will it work?
01-08-2018 01:19 AM
Are you able to make outgoing call and outgoing text?
Public mobile doesnt have 2G netowkr as rogers. it all relies on 3G connection.
01-08-2018 12:39 AM - edited 01-08-2018 12:42 AM
It looks like you've got a phone has only limited compability with the Telus network.
I'm actually surprised that it connects for calls and texts.
From @sheytoon's post that I linked to:
@sheytoon wrote:Minimum recommended phone specs:
- 3G UMTS/W-CDMA/HSPA: B2 (1900) and B5 (850)
- 4G FDD-LTE: B4, B5, B12/B17
Currently VoLTE is not available and voice calls are only on 3G. SMS and data can work on 3G or LTE. Fastest data speeds are on LTE.
For LTE, these are all of the available bands on the network: 2, 4, 5, 7, 12, 13, 17, 29, 30. Some bands are available in some locations, others available elsewhere. B66 will be coming next.
Any phone you are considering should have B4, B5, B12 (or B17 instead of B12) for minimum coverage.
B2, B7 (and B66 shortly) will give you faster speeds. The rest are not really necessary.
The only band that the network and your phone have in common is band 7. Band 7 is not available everywhere, though.
01-08-2018 12:00 AM
phone calls and text messages both work.
01-07-2018 11:58 PM
01-07-2018 11:42 PM
@Ed wrote:Hello,
ED
I couldn't find the manufacturer's website, so can't confirm... Are you sure your phone supports PM's / Telus' LTE frequencies?
01-07-2018 10:55 PM
@Ed Check your APN settings.
