Charged Twice
maggiedima
Hello,
Upon choosing US Roaming for $20, I submitted my payment and the message was "Oops.. it didn't work..try again", so I kept clicking payment now and I got charged twice, now I have 2 US roaming plans and a $10 credit.  My credit card was charged $22.60 and $5.65 extra.
Thank you,
Maggie Dima
maggiedima
Hello DDM69,
I have contacted the Customer Service Department and will provide the information requested by them for further resolution.  Here are my screen shots:
Thank you,
DDM69
Can you provide a screenshot of your charges?  I don't believe you can add 2 US roaming plans at the same time.  Also, wouldn't the charge be $20 twice?  That would be $40 plus taxes.
@maggiedima   no worry, this likely something PM can easily help
First login to My Account using Incognito mode, check if the duplicated charge sitting as Available Fund there.  If so, you can leave it there for use for next renewal
If you don't see it, open ticket for PM support using Chatbot:
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
@maggiedima
Contact an agent:
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here
