05-04-2023 08:20 AM
I was just charged 4 times (46$x4) and every time I try to submit a ticket it takes me right back to the login. I’d really like to get refunded asap
05-04-2023 08:54 AM
Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
To Contact CSA-agent there are 2 methods:
Ticket has to be opened through chatbot - https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Having a ticket is preferred way to contact agent as they might respond faster then receiving personal mail.
If opening a ticket does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking (Ctrl+) Here
Agent’s response is usually between 15 and 120 minutes with a ticket. Private messaging might take longer.
Watch for envelope in top right corner of Community page. It will show Number of unread emails.
05-04-2023 08:32 AM
yes, you need to submit a ticket for a refund request
Please note that for the validation step when you use Chatbot to create ticket, choose to use the 4 digits pin instead of My Account login. If that does not work, please message support directly here :
