Changing Sim card
Burgess93
Lost card got new one want to change email and keep number how that work I lost my Sim card got new one want same number
2 REPLIES 2
@Burgess93
for changing email used for My Account login only support can help. Please open ticket with them.
1.  Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
Once email changed and you can login, go to My Account from ONLY a desktop or laptop computer to request Change Sim card (please note that due to some glitches, accessing change sim care from mobile phone or tablet won't work)
After you logged in, unsuspend first if you have suspended your service earlier.
Then click Quick Links on the top right and select Change Sim card and follow the steps:
https://selfserve.publicmobile.ca/en/account/edit/your-accounthttps://selfserve.publicmobile.ca/en/account/edit/your-account
@Burgess93  You need to do this on computer only not a mobile device and to a SIM card swap
Do not activate the new sim just swap it under the profile tab quick link
My account
Legend  and features
Change plan / update cc /auto pay
Account #/ change # port /swap SIM
adding also if you want to change your email you need supports help to do that and ask them to swap SIM card for you at same time also
  • Get support by starting a conversation with virtual Chat box /SIMon. Click here
  • you can send a private message   To CS_Agents by clicking here.
  Watch for reply top of page to the
   Right ( envelope image )
