Changing subscription
Atousa
Hi, I want to change my subscription from $15 plan with 100minutes/250MG to $45 with 40G 5G and unlimited text and talk. When I went to check out, it didn’t deduct my $5 rewards and it looks like I have to pay the full price. Is that correct?
DennyCrane
You don't get rewards for early renewals, otherwise you'd be doubling up on monthly rewards. Best to schedule the plan change for your renewal date so you get all your rewards and so you don't lose out on the plan you've already paid for.
@Atousa  You will pay the full amount now if you do it immediately . Instead change plan for next renewal and the reward will be applied and you won’t lose money in your current cycle
Add pic
Change plan in 3 easy clicks
Once you find plan you want be sure to (change on renewal )So you don’t lose money on current cycle
dust2dust
That is correct. Have a read of that disclaimer box. When you do an immediate plan change you need to pay the whole thing and you start a new 30 days and you don't get the remains of your old plan pro-rated.
