Changing plans
Diogenes87
Hello, I'm currently on the $15/month plan with $6 in rewards. If I change to the $34/month plan will my rewards stay with it? And if I change back to the $15/month plan later on will my rewards also stay?
@Diogenes87  Yes so long as the $15 plan is still available when you want to change back . Which I do t see being a isssue as that’s a staple plan of PM . But the no data from the 50GB $34 plan will roll over PM is pre paid and no refunds or prorating
@Diogenes87
you can downgrade back to $15 plan as long as it's still available. Data will NOT roll over...use it or lose it.
Diogenes87
Okay and I should be able to go back to the $15/month plan if say I try out the $34/month plan for a month or so? Also will any unused data from the $34 plan be rolled over to the new plan?
@Diogenes87  You won’t lose your rewards they will stay the same I made this plan change and kept my old rewards
Changing from one 30-day plan to another won't cause any change to your rewards.
Dunkman
@Diogenes87
Yes, if you change plans, the legacy rewards will stay the same.
