Changing plans not showing up
05-02-2024 05:35 PM
Hello,
Trying to change my plan to the $21/Month - 3GB data (Brand new). When I go into my change subscription it doesn't show this plan. I was at $20/Month - 1024MB of data, so I wanted to be at the same rate but with the new plan. It didn't offer me that new plan. So I decided to upgrade it to the $30/Month plan and hoping maybe in the next day it'll show up the $21/Month plan and I can change it possibly.
Why doesn't it show up? Is there a bug? I want to pay $20 not $30 as I don't need that much data.
05-02-2024 06:18 PM
Thanks for the info! 😀
05-02-2024 05:39 PM
@Katapult775 - The plan is for New Activations only, so you will need to contact CS_Agent politely and you have a 50/50 chance of getting the plan. Also you will lose all of the rest of your plans month by CS_Agent.
Submit a ticket via Chatbot:
⬇️ Click the link for an Agent * ⬇️
* - CS_Agent will typically get back to you within 48 hours. They work 7 days a week from 9 AM to 10 PM EST. You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for one of the agents responding back to you because they may notify you asking for some information via Private Message, in your community mailbox by clicking this link here: Mailbox
05-02-2024 05:39 PM
@Katapult775 That’s because the 3GB for $21 is for new activations only not existing customers like you and me . You can try asking support if they will be willing to switch you to the new activation plan . Some have verified getting the new activation only plans in the past just by asking for it
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send direct private message to support .
send a private message To CS_Agents
