07-25-2021 01:50 PM - edited 01-06-2022 02:54 AM
I have to get unlimited Canada to U.S. calling and highspeed 20GB data.
07-25-2021 02:44 PM
As mentioned in previous posts, if you are looking for higher data plans, Public mobile plans are just not competitive enough these days. You can find better deals with higher data plans with other mobile companies. Shop around.
07-25-2021 02:16 PM - edited 07-25-2021 02:17 PM
07-25-2021 02:12 PM - edited 07-25-2021 02:13 PM
The closest you are going to get would be the $70/15.5gb plan and use the promocode 2GBBONUS upon activation to recieve 2gb of bonus monthly plan data as long as you stay on your rate plan. Unlimited US calling ( from Canada) is included in that plan.
07-25-2021 02:05 PM
07-25-2021 02:02 PM - edited 07-25-2021 02:25 PM
07-25-2021 02:01 PM
@Srithar , this is all the plan offerings that are currently available. You might be disappointed that there's nothing with the features you are seeking.
07-25-2021 01:56 PM - edited 07-25-2021 01:58 PM
@Srithar Reading what you have asked, maybe PM cannot fulfil what you want. So, the Change Plan instructions suggested above might not be needed for you.
PM does NOT have 20GB plan. the most they got is 15 GB for $70. Also , there is NO high speed LTE plan here, they only have plan throttled at 3Gbps on LTE network
You might consider going with Telus or Koodo instead. they offer full LTE plans and more data. With the amount you pay, you might even get phone discount.
07-25-2021 01:54 PM - edited 07-25-2021 01:59 PM
the $50 Plan Details:
or
the $70 Plan Details:
How To Change Your Plan
When you’re changing your plan, you can choose to change immediately or at your next plan renewal date. To change your plan: sign in to Self-Serve, select ‘Change Plan’ on the Overview page, select the plan you want, and scroll to the bottom of the page.If you’re looking to apply a promotion to your plan, learn how you can do that here.
Changing your plan on the next plan renewal date
We recommend you choose this option because it allows you to use the services you have already paid for until your next plan renewal date. Here are some things you should know about this option:
Changing your plan immediately
You may choose to change your plan immediately if you have used all or most of your services, or if your account is suspended and you would like a different plan. Here are some things you should know about this option:
What will happen if my payment wasn’t completed?
In this scenario, your account could still move from suspend to active, re-starting your plan cycle and potentially only reactivating a portion or none of your services. If you find yourself in this situation, simply go to the “Payment” tab in Self-Serve, choose “One Time Payment”, and opt to pay the “Amount Due”. This will cover the new plan cost less any partial payment that was taken. After successful payment, your services should be fully reactivated. If your services aren’t restored,please start a conversation with our virtual assistant, SIMon, to submit a ticket to the Moderator Team by clicking here.
