06-05-2019 05:48 PM - edited 01-05-2022 05:14 AM
I want to change my plan from the $40 4.5 gb plan to the 6+2gb for $50, it says I can top up to switch now, do I pay $10 or $50? Does it change my date or just give me more data within this billing period?
My top up day is June 8th, almost out of data now so wanted to change my plan!
06-05-2019 08:50 PM
@amandakennedy, if you are doing this because you’re out of data, in this case as your only 3 days away, if you NEED the data, $50 is a better option than paying $30 for a 1 GB data add on for 3 days (which you keep intil it is fully used.
06-05-2019 05:54 PM
06-05-2019 05:50 PM
@amandakennedy wrote:I want to change my plan from the $40 4.5 gb plan to the 6+2gb for $50, it says I can top up to switch now, do I pay $10 or $50? Does it change my date or just give me more data within this billing period?
@amandakennedyIf you chose immediate you will need to pay $50.00 and you renewal date gets set 30 days from today.
