11-27-2023 02:08 PM
Is there a way to change my temporally phone number with public mobile?
11-27-2023 02:29 PM
Hi @Yossy107
If you go into your profile, you can change your number to options they provide. Although, if you happened to have a number you really liked on say Fongo or TextNow or any other VOIP program, as long as they are under your name, you could port those over at no charge.
11-27-2023 02:15 PM
@Yossy107 Yes, you can login to your self-serve account to change your number.
11-27-2023 02:14 PM
HI @Yossy107
what you meant by temporally phone number with PM's?
you want to cancel a port in request? if you are, login My Account, Profile, click the edit pencil beside phone number and pick a new number. With a new number, it will stop the earlier porting request
