08-27-2020 07:24 PM - edited 01-05-2022 03:41 PM
When I call people, it comes up as a private caller. However, I would like my name to come up on the screen for people so they can readily identify me if I am not in their contact list. How can I switch to this?
08-30-2020 03:09 PM
Regardless of whatever the menu options are in a phone to do block outgoing caller ID, here is how you can change the default outgoing caller ID behaviour manually on any phone:
You can make outgoing caller ID blocking permanent for all future calls by default by dialing *31#
When blocking outgoing caller id by default, you can enable it "per call" by prefixing *31# to a number (ie *31#xxxyyyzzzz )
Return to to allowing outgoing caller id by default by dialing: #31# alone, which is what I believe you're after.
Regardless, only your number, not name, is sent to the recipient of your call unless your number is in their contacts only then will your name show.
08-27-2020 07:57 PM
@chosie , check the settings on your phone app. It might be set to block your number and so the recipient will not know who the caller is.
08-27-2020 07:26 PM - edited 08-27-2020 07:28 PM
Hi @chosie ,
The people you are calling will need to add you as a contact for them to see you as your name.
Public Mobile does not have outbound call display for the caller's name (only phone number displays).
