Changing email
AdamDio
I have gone into edit profile to change my email, but there does not seem to be an option for it. Is this something that I can do?
AdamDio
Thanks
AdamDio
Thank you!
AdamDio
Thanks!
HI @AdamDio   Yes, you are correct, there is no option to make the change  😞
But you can have PM Support to change for you .  Please open ticket by clicking
on the Bubble or directly at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
  1. type: Change username
  2. Click " Forgot Self-Serve Email"  (yes, you still pick this choice, this is the closest one)
  3. Click "Contact Us"
  4. Click "Click here to submit a ticket"
  5. you will then direct to another page to open ticket.
If you have problems submitting a ticket, you can also send a private message to the moderators (but this can take longer):
BeachNBeer
@AdamDio  two different sections to change email.
1- Community Forum account (where you're Posting now). Click your badge top right then select my settings to change your email.
2- To change your self serve email. Where you make payments look at your overview page, add-ons , etc you need to contact support as they are the only ones that can change it. Click link below to contact them.
send a private message to:
and describe your issue. Include your name,phone #, account #, Email address,4-digit PIN to speed up authentication
