06-19-2022 07:52 PM
I tried to update my credit card information for two phones but I am not able to get the information to go thru. Could someone please advise me as to what I have to do. Thank you
06-19-2022 08:04 PM
@mecorbett105....
06-19-2022 08:01 PM
@ if above trick does not help,
1. you can open a ticket through Simon here https://publicmobile.ca/chatbot.
type need help to change credit card information
2. alternatively you can private message them here
06-19-2022 07:58 PM
HI @mecorbett105 it is usually less trouble to use the Replace credit card option instead of delete and re-enter.
If it failed couple times, it could trigger a fraud lock
Not sure how many times you tried, but open ticket with PM CS Agent and have them to help:
Once ticket is submitted, make sure to check your Community Inbox(top right corner envelope icon) periodically for response from PM's CS Agent
06-19-2022 07:54 PM
@mecorbett105 hi instead of trying to update cc info use the remove option and start fresh
