Changing card details in autopay
nimypaul
Hi I couldn't change the card details in autopay.
geopublic
To make changes to your Autopay click the My Account buttom top right of this page.
1) Login to your Acount and click Payment tab.
2) Below "One Time Payment" and "Manage Auto Pay" options there is a very small link
Manage my card - Update or remove my Credit or Visa debit card
3) Two options are available: "Replace this credit card" and "Remove this credit card"
Use "Replace this credit card" to update the CC info like new exipry date
Use "Remove this credit card" if you want to use a different CC.
Hope this helps!
popping
The credit card edit function does not work.
Delete the old entry and add a new credit card even it is the same credit card.
Lieux
Did you go here in MANAGE MY CARD ?
shskr
Delete card and then renter it is a bit finicky.
