Changing a plan in the middle of billing cycle?
irisxiaolu1
Good evening everyone,
If I were to change my plan in the middle of billing cycle, how does it work? Would I get some refund for the current month? A new bill month will start immediately. All data left on my current month will be wiped out?
Thank you very much!
Iris
NetworkNinjaOG
I often check PM subscription offerings.  I change my plan about 1 to 2 times a year. Always getting more data at a cheaper or same rate.  Usually around the Black Friday time (November).  I always set it to renew on subscriptions as mentioned already in this thread, as you will loose current subscription if you select immediately.
Public Mobile's plans are not by the month. All of Public Mobile's current plan are either 30 or 90 days in duration.  An immediate plan change cause total loss of any usage remaining from the abandoned plan and there will be no refund/no credit issued.  To avoid that, changes would need to be pre-scheduled for the next renewal time.
@irisxiaolu1
no, you won't get partial refund for the unused days if you change plan early
Unless you need the extra data immediately, then use Change Now option when you make the plan change
But if not, we suggest to schedule a plan change using Change on Renewal to avoid losing money for unused days from early plan change
