Changing Phone Plan
PublicMe
My appology if this topic has been covered before and I can't find it.
But, I signed up for the wrong plan and hoping I can change it right away but the website says that I have to wait untill my next payment (which is 90 days)
I'm just wondering if there is anyway to change it without having to wait for my next payment?
Thank you
If u want to change plan log in self serve and click on my plan once it's open then u can click on change plan where u will see lots of options make your selection according to your need
** I am not a Mod, please do not include any private info in a private message to me.**
PublicMe
Thank you!!!
Acekiller
Here you go
@Shazia_K, @Mary_M, and @Saray_O
Shazia_K
Retraité / Retired
Retraité / Retired
Hey @PublicMe,
Mod here! 😄
If you hover over your pointer above my name, you will see the option of sending a private message 😉
Cheers,
Shazia
PublicMe
Thank you for your reply!
But how do I contact a "mod"?
NDesai
Hi,
If you forgot to select the main component such as Talk or Text, send a private message to one of the mod. They will see what they can do.
In other case, you might have to wait till your renewal date.
