Changed plan, today is renewal, OK to make calls, but unable to receive calls.
EasyDay
I guess I have to post my issue here, in order to solve the problem?
@EasyDay wrote:
1st time post a question here... 😁... I just submitted a ticket as well.... got a ticket reference number now... Hopefully that works... 🤞
If this is the new issue happening @EasyDay I hope to hear that a CSA fixes this for your asap. I wonder if they will share what happened or why this occurred.
If this is some strange glitch network-wise, have you tried any troubleshooting? If not, why not try some of these while you wait for a CSA to respond and see if anything helps:
Try 1 or more of the below:
  • restart your phone
  • toggle into and out of airplane mode
  • perform a Reset of the device's Network Settings
  • move your sim card to another phone to see if services works
  • manually select the 3G / WCDMA ONLY network in your Mobile Connections area in your settings (temporarily) to see if services work
EasyDay
Alexandf
@EasyDay
send a private message to   CS_Agent
There have been several complaints about this issue with customers being affected by this. The Oracles have also informed Public Mobile.
