Change to a new plan and lost all my rewards why?
JuniorZandre
I just changed my plan and I lost all my rewards Why?
8 REPLIES 8
HI @JuniorZandre
no worries, from your screenshot, you are very safe
if you want to double check, click Rewards on My Account, then go to Rewards site from there and you will see everything showing the correct rewards.  In fact, that will also confirm the amount of rewards you will get next bill
JuniorZandre
Thanks .
JuniorZandre
No, Been with PM for long. had loyalty and subscription
HI @Gag
no need to wait , OP already shows screenshot clearly showing old rewards system.
if people on points, they won't see those line items
HI @Gag
dont' scare OP, from the screenshot OP didn't change to rewards points
Gag
You must have joined public mobile new Points system that will take all your loyality,autopay etc points
Andy85
@JuniorZandre I would check back in a day or so. The site is likely recalibrating your plan selections and your pre-existing rebates will appear once again. I probably understand how you're feeling right now but I wouldn't worry.
HI @JuniorZandre Look like this is the Upcoming bill section, wait 24 hours for it to update
But if you just change plan using Change Now, PM will charge you the full plan amount first, and you will see those rewards credited back into your account in the next couple days
