Change subscription plan
Koombassi1
Am I able to switch plans for one month without additional fees.
sorry @Koombassi1
you cannot change plan for one month thinking you can go back to the old plan after
no carrier allows that
hairbag1
@Koombassi1
you can change to whatever plan you see in your account...BUT...be careful as it's nearly impossible to downgrade once you've upgraded to a more costly plan.
@Koombassi1  You can only chage to the plans that are available to you in your account despite what we see on the website and you can change plans when ever you want it’s always advised to use the change on renewal option and not immediately so you don’t lose $ on your current cycle . Also note if you do change plans you might not. Be able to get your old plan back also
