Puk pin
ttressa
Ive been lock out. I have ticket and nothing.
Im not sure if anything or anyone will help.
So frustrating.  E-sim locked with this code. How is possible. Ive sims never were like this.
ttressa
Im confused ? So no one is going to help with a pin? So only solution is buy a new one ? Why cant i have a pin? They provide. Im confused what ?
slusagm
@ttressa
the quickest way to resolve PUK issue with eSIM is to buy a new one.
Login PM app  on your phone with Wifi, then go to Account->Purchase sim card and choose eSIM
if you cannot login the app or would like a PUK code, please ask PM.   Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
Chalupa_Batman
If you are able to log in, please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket. Enter CONTACT US into the chat and follow the prompts.
If you’re unable to log in to your account, please use this direct link to reach out to a CS Agent.
You've mentioned that you have a ticket, just to confirm the above is how you did it? On the weekends customer service is slow. Because this is a self serve service with no "instant" support, it make take up to 48 hours for them to respond. Just keep an eye on your community inbox.
