08-28-2018 02:39 PM - edited 01-05-2022 12:42 AM
Hello,
I just took 2 new plans yesterday
I had them both incorrectly assigned as $10/month, I would like to change it to the $40/month ULC and Data promotion, since i have already paid $10 would like to use that as part of the plan payments, I cnnot do that from selfserve.
Thanks
Ivan
08-28-2018 02:57 PM - edited 08-28-2018 02:57 PM
Done, removed phone numbers too Thanks.
08-28-2018 02:55 PM
Thanks, might try that, I did also send them a private message.
08-28-2018 02:44 PM - edited 08-28-2018 02:44 PM
@ivanfernandes message the mods with details of what you want. There is a 24-36 hour delay though.
If it was me and if the time lines don't work I would simply do an immideate plan change and ask the mods to credit as available fubds you the costs of the 10$ plan. They are pretty good with goodwill. But it's not guaranteed.
08-28-2018 02:42 PM
1. You should remove your phone numbers, this is a public forum.
2. You should send private messages to the Moderator Team to change your plan. Normally you can't change without having to pay again, but the Moderator Team usually accommodates changes for new customers.
