01-14-2025 02:20 AM
Hello,
Although I renewed my plan on Jan 5th, before the offer expired on Jan 6th, my card was charged the old amount. How do I get a refund?
I would like a private message.
Thanks,
01-14-2025 02:28 AM
Here you go If you want to private chat the customer.
You will need to open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
