Change plan back after text offer
SeanMc
I recently received a text offer for a plan upgrade and mistakenly auto replied yes when I tried to cancel the alert. I do not want to change my plan at this time, but cannot fond a mechanism in my account to cancel the upgrade, which is due in 3 weeks.
is there a way to accomplish this?
thanks!
12 REPLIES 12
TooStinkenTrue
it shouldn't change to the new plan until the current month is over... if you log into your account, then click "plan and add-ons", the top banner will show "current plan". Click "change my plan" and there should be an option to cancel the add-on/plan change. I hope this helps!
@SeanMcJust to be very sure,   check back My Account using Incognit/Private/Secret mode tomorrow to confirm.
If you had to reply yes and don’t do it caps onYES like that it most likely wouldn’t have changed
SeanMc
Thanks again,
I definitely do not see anything like that, so I’m going to assume the reply I accidentally sent didn’t register.
@SeanMc   if you don't see something like this, then you didn't schedule a plan change
Of course if yo see that, then you click Cancel Plan Change
if you want to be very sure, open ticket with CS agent to confirm
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
@SeanMc  You should see it there under where you see your current plan your on
SeanMc
Thanks for the replies, but there does not seem to be anything like a scheduled plan change option in the Plans & Add-ons section.
HI @SeanMc   you can cancel the schedule plan  change
Login to My Account, go to Plan & add-on page, click Change my plan, you will then see it shows you a scheduled plan change, you can cancel it there
dabr
@SeanMc   Use incognito/private mode to login into your account and you can cancel any scheduled plan change in there or if the change has already happened, then select Change My Plan and then schedule a plan change at next renewal since PM doesn't prorate for unused days left in current cycle.
@SeanMc @Log I to self serve go to plan add on tab and it will say scheduled plan change , following instructions to keep it on course or do not change at renewal
 After looging int your Self Serve account, go into the Plans and Add-ons section. There is a link to remove the scheduled plan change.
